RCU Forums - View Single Post - transmitter damage due to antenna down while on (?)
Old 01-11-2004, 12:10 AM
Azcat59
Default RE: transmitter damage due to antenna down while on (?)
I have a JR 8103, but so far haven't left it on. In addition to the range checks, check your battery reading after charging, AND check all your computer settings for the airplane in use, i.e. make sure servo reversing is the same as you had set, dual rates are still as programmed, etc. If it lost any of these settings it could cost you your airplane.
Clair
