Sanding Leading Edge
If you are concerned about a precision L.E. shape, make an accurate template and use the razor plane to shape the L.E to fit. To use a shaped sanding block, the block itself must be a precision mirror image of the desired shape, and I don't know how to create such a precision cavity, especially when you have to add sand paper into the groove and still maintain the accuracy.
