Old 01-14-2004, 02:10 AM
CapttRob
Default RE: hinge slot cutter
I used my Dremel with round cut wheel bit. Drew my centerlines and cut each hinge slot with ease. No digging. If you need to widen the slot more just move the wheel back and forth in the slot or open it a bit with a razor after cutting the slot with the wheel. Hinged all my surfaces including flaps with Dubro and pins. Works great.
