RCU Forums - View Single Post - 1/2a Piper J3 (Video)
Old 01-16-2004, 06:48 PM
Andrew
Default RE: 1/2a Piper J3
ORIGINAL: DICKEYBIRD
I like the .070" stuff because you can sand one end down slightly and CA it into the little 2-56 threaded brass doohickeys and screw on a nylon mini-clevis.
DB --
How stiff is the .070" rod? Can you use it for a full length ( 12" to 14" ) pushrod without support in the middle? Could it be used as an aileron torque rod for barn door ailerons on the tip of an 18" wing panel?
the "other midguided" Andrew [8D]
