RE: Glitches on Eclipse 7
I don't know the size of the wire in the extension leads. I see your reply in another post they should be 22G or larger. These are JR extensions I had on hand. I presume JR would use the appropriate size wire. One of my extensions is a Y I had on hand. I'm only using one side of it for the extension. That leaves an unused wire running the length of the fuselage. Possible problem? If one of my servos was reversed I wouldn't need to slave it on channel 7, but could use the Y. Could I send the servo in to Hitec and have it reversed?
