fainjon - bend the surface all the way up and put some clear packaging tape or iron on film in the gap underneath. It should be about 1 1/4" or so wide so you can get at least 1/2" ironed on each surface. The gap only needs to be sealed on one side.
You can also put it on top. Either side is the same, but it generally looks better where you can't see it.
