RE: ENGINE CASE REPAIR
I've come across a cheap DIY system for repairing cracks, and possibly welding custom exhaust systems. The shadow that is in the vicinity of the upper left backplate screw hole is where a left a slight amount of the filler rod above the surrounding metal. The stock needle valve/ backplate puts a lot of pressure on the engine case in this area when you go from 50 MPH down to 0 real fast.
