RE: u-can-do 60
Cant believe i just "stumbled" across your info on th U-Can-Do !...finally managed to get one two weeks ago,exactly the same reasons for buying it as yourself,had a new O.S..91FSIIP 'in stock' so to speak and that O.S mount, but i thought that was going to be about an inch or so short ? I WAS going to use canopy glue, thanks ! Bought the 475's and tank last week, got some carbon fibre ( fiber ?! ) rods and M3 clevises yesterday ! and would you believe..i ordered the True Turn 'wide' cut spinner & a couple of Zinger 15x 6pro props from Tower round midnight last night !....Sounds like i've got the same R/C gear as you ...Now then !... how do i mix the elevator and ailerons ? is it PMX1..PMX2..or what ? i've wrestled with this one into the small hours, till i Knew i was the only one on the planet to stupid to grasp it ! regards sir !... & HELP !
