RCU Forums - View Single Post - Clost thread
Thread: Clost thread
Old 06-02-2002 | 01:19 PM
crosswind
Default Clost thread
You don't need to stretch it. Just get it as smooth as you can, seal the edges, and as you apply heat to the center section it will shrink drum tight. The only time you need to stretch it is when covering a curved surface such as wing tips. You then apply heat and slowly pull it around the part you're covering, sealing it down as you go. Often it's best to use more than one piece for curved surfaces.
