RE: Battle of the retracts: Century Jet vs. Robart...Need some advice
Go with the Spring Air gear on a plane this size. If you have to have scale struts you can always add in the robart struts later. In the end spring air will be cheaper when you add al the accessories including the oleo struts that you can source from robart.
Chris
