RE: Prop Expert?
The apc props are heavier and they dont have any give when you crash. Gws props will shed the blades instead of busting up your gear box(usually). Some aplications will require apc prop because the gws prop wont be able to handle the load. I make my gws props prettier by painting them black with a sharpie.
You could use the apc with a propsaver also
