RE: Aileron Reflex Tricks
I may be pushing this thread a little further out, but help me if you can...
I have a Hergett 1/12 P-51, built by John "VooDoo" West. I have a Magnum .25 stuffed into
the nose & it is unbelievably fast. I have always had to trim for level flight with the elevator
a little down. I have double checked CG several times. I recently lowered the incidence, but
I still have to add what appears to be the same amount of down elevator. Could I use your reflex
adjustment to correct this? It's not a real big deal, because it is so fast & flies so good, but it
does bring up an interesting problem & a possible solution.
Johnny C!
