RCU Forums - View Single Post - ARG, 3M 77 eats foam
Old 02-08-2004 | 06:56 PM
Boss248's Avatar
Boss248
Default RE: ARG, 3M 77 eats foam
I read where some builders are just taping the wing skin sheets together at the seems and using the poly glue to glue the sheeting down..as the poly cures it sseeps in the taped joint of the balsa skins and when it cures is easily sanded leaving no seem line.
I always used 3M#77 but will be using poly glue or epoxy from now on.
