RE: RE: RE: Sig Mayhem 3D ARF
I'm not sure what you are asking.
I only followed the book and correction page.
The CENTER of the tank is just about that of the needle valve on the OS 1.2. Note that the tank tubes are ABOVE the center of the tank. The tank position is fixed by the bulkheads
The cowling was shaped by chucking a 1/2 in Dremmel sanding drum in a drill press. Holding the cowl steady is easier than you might guess.
The engine has a flapper choke valve attached to the intake. I removed it to make way for the tank tubes since I haven't had to choke the engine here in southern Florida. (sorry northerners)
I have not run the engine yet.
Fire back if your question is not answered.
Tailwinds,
Robin
