RE: FM or PCM??
To sum up all of the information the answer to your question is yes- PCM is better on both counts. Only you can decide if it is enough better to justify the extra expense. If you fly in pattern competition you have to spend the extra money, but otherwise as you say PPM has worked for you before. PCM is not going to make you a better pilot.
