RE: FM or PCM??
Ditto... PCM may not be a perfect system, but overall it is better than PPM without error checking. As with any system, you must fully understand how to use it or risk problems. Be sure you understand how to range check a PCM system and fully understand failsafes and how to set them up. If you can afford the few extra bucks, use PCM or a similar error checking encoding such as IPD... one day it may save your plane, or more importantly a life.
