Thread: FM or PCM??
Old 02-11-2004, 05:34 PM
tadawson
Default RE: FM or PCM??
Since IPD is PPM, and most PCM systems set the failsafe points in the TX, which loads to the RX via the PCM data link protocol for that MFG, how, exactly, do the failsafe positions get set in IPD? Since there is no inherent protocol to transmit them to the RX, I assume that this would then require the annoying step of having to set them with a button on some such on the RX?
- Tim
