RCU Forums - View Single Post - MARUTAKA cessna Skymaster Kit questions
Old 02-11-2004, 08:33 PM
OV10
Default RE: MARUTAKA cessna Skymaster Kit questions
Anthony
Covering is white coverite
Thinking about trying latex w/clear coat
I'm sure the rear engine will be the one to fail, cooling at first, the 65 will be enough to fly even with the rear engine dead also tail weight and I had both engines.
Yes air scoop is functional as per plans
Did not use bell crank to control elevator, servo is in hatch under wing as with rudder
No flaps
David
