Thread: FM or PCM??
Old 02-12-2004, 04:11 AM
HarryC
Default RE: FM or PCM??
ORIGINAL: JohnWillman
PCM drops bad frames and IPD reduces resolution... the net result is both feel mushy in flight. With IPD, no frames are refused, but resolution is reduced as it absorbs bad frames and the result is sluggish response.
That is not correct. IPD rejects bad data, it does not reduce resolution, it does not absorb bad frames. As soon as one servo's data is invalid the remainder of the frame is rejected and replaced by failsafe data.
Perhaps you should learn a bit more before accusing others of not knowing how the system works.
H
