RCU Forums - View Single Post - Lanier Stinger .60 ARF
Old 02-18-2004 | 10:35 AM
swfthunderbolt
Default Lanier Stinger .60 ARF
I bought a Stinger ARF .60 size.
It has a few strange problems.
Comments on the following are very welcome.
1) the Landing gear are swept back which is very strange considering I have never seen another like it (with the gear swept back), I'd like to turn them around but then the wheel pants then would be at a bad angle; touching the ground.
2) Next the directions call for putting the elevator servo against the fuse wall and the rudder servo in the middle, it seems to me it should be just the opposite. I think this because The elevator push rod should be pushed straight back for the two exiting rods to the elevator while the rudder rod is on one side.
3) Should I paint or glass the out-side of the fire-wall for the purpose of fuel proofing? I'm using a four stroke YS.
Thanks in advance,
From Fort Worth, Tx
