RCU Forums - View Single Post - Trust Question
Old 02-20-2004 | 07:05 PM
Johng
Default RE: Trust Question
ORIGINAL: MiragePilot
Re: cold air vs. hot air
The energy of a given mass of air is a function of the specific heat of the gas X its temperature. The higher the temperature, the more enery ity has (which can be expanded through a nozzle to generate THRUST). An afterburner is a classic example of this physical relationship.
Peter
And what does this energy in the form of heat get you? Nothing but design headaches. The energy is useless unless it is converted into thrust, by way of pressure. Pressure - also another way air holds energy. More exhaust temp does not necessarily mean more thrust. More pressure means more thrust. In fact, the heat leaving the engine in the exhaust is wasted energy, a by-product of heating the air to gain the pressure increase. A more efficient engine does a better job of converting heat into pressure.
