new tx help
hello all i just bought a new JR 6102 i plugged it into the charger according to the manufactures specs and let it charge 24 hours when i removed it from the charger and turned it on. it came on then started beeping then i got a low battery warning then it shut itself off do i have a bad battery or is the charger bad also the charger was very hot but according to the directions it say that the charger will get hot
thank you in advance for you help
Rich
