Actually the TP2100 are rated 6C, which is about 12 amps.(Depending on which Web site you read.) I had forgotten that the Kokams were 8C and therefore will take 12 amps also. I mistakenly thought the Kokams were also 6C and therefore only 9 amps.
The GWS EPS400 on a 5.28 gear box only pulls 8 amps off the 3S spinning a 12x8 HD prop. Shouldn't be a problem on Kokams either.
Sierra Gold
