RE: "DON SMITH " B-17'S?
Thanks Flydoc for the response...When I saw your plane in the stage of the water pipe on the web , I was wondering about the twist factor,But from looking at your plane and the way it looks now,I see that the water pipe worked great..Anyway the square pipe is working great also..Planking will be easy because right now I can plank the top and starboard side and then the port side by just turning it end for end and then the bottom by simple flipping it..I had a bit of a sag problem with just the lenght of the pipe being held at the ends so a support for the middle was made..Is this what happened to you? Michael
