RE: Best AXI for a Dandy Sport?
The 2212/34 will swing a bigger prop and give more thrust. That is important to me because of the small field with trees I fly out of. I need a good climb rate. I believe the 2212/26 uses smaller props with greater pitch. It should hit a higher top speed but not as much thrust.
Dr Kiwi, Matt, help me out here. Am I guessing right?
Dr. Kiwi has an excellent spread sheet of his test results for the 2212/34. That was another reason I choose it. Also Dr. Kiwi never lead me wrong and it was one of his picks.
