RE: Low motor speed
Thanks for the info Doc, but since the motor runs faster if I bypass the transmitter, could there be some quick fix on the transmitter or adjustment on the transmitter to obtain more speed. Its a 4 channel Fataba and you can slide the slide adjuster beside the throttle knob up all the way and gain a little but the throttle does not begin to turn the prop untill I am about half way up on the throttle.
