RCU Forums - View Single Post - newbie help
Thread: newbie help
Old 03-02-2004 | 12:06 PM
gcb
Default RE: CL Newbie
ORIGINAL: Dr.Weasel
Thanks guys I think i'm going to go with the Sig Skyray and and Norvel Big Mig. Does that sound ok? Do any of you know where I can get engine parts for my Cox sure start .049? I shattered the mounts on the choke tube (nose dive). Its funny i actually was in computer class. It was ok with my teacher after i finished a test.
Thank,
The Doc.
P.S. A scout is trustworthy, loyal, helpful, friendly, courteous, kind, obedient, cheerful, thrifty, brave, clean, reverent and always hungry. ( had to bust my book out for some of those)
I would suggest the "Startup" for your first BigMig engine. It comes with tank and spring starter. You might want to shorten the front of the fuselage about 1/2" for the large Norvel tank.
If you really only broke the choke tube, it will run without it. The engine used to come without the choke tube. If you need the mount, do a search on Cox engines or see your local hobby shop.
The throttle is usually done with a three-wire control system and is usually only used for scale or carrier airplanes. I would wait a bit for those.
When I was SM my SPL would usually start the troop meetings with the Pledge OF Allegiance and end with either the Scout Oath or the 12 points of the Scout Law in a friendship circle. This helped new Scouts learn them.
George
PS. As you cut out or trim the parts of the Skyray, trace them on the back of the plan so you can make a replacement part when (not if) you break one.
