RCU Forums - View Single Post - YS 61 R Problems
Old 06-09-2002 | 11:50 PM
limd
Default YS 61 R Problems
Hi I have a YS 61R bench mounted for running in. I am currently running a 12.5 x 8 prop and 20% castor . The engine is fitted with a tuned pipe.
I can only start the engine when I prime the carby. The needle valve is 2.5 times open . The engine fires up then stops. The throttle setting is on idle with full trim "on" . When I advance the throttle SLOWLY the engine dies. I have tried the needle valve in a variety of settings with no luck. The plug is an OS no8.
Any help would be appreciated. Thanks
Dave
