RE: Pushrods
2x56 or 4x40 are the thread sizes on the end of metal pushrods. The 4x40 is a larger diameter and may be needed if you have larger surfaces and a speedier airplane. If you use either for the full length of the push rod make sure your antenna does not parallel them. If you use Golden Rods or similar plastic push rods and housings the wire rods will require threading into the plastic inside rod.
