RE: Brushless Motor questions.
Okay here's the redone stats. Looks pretty well so far. And if I transfer over the motor, gearing, and go with a different prop size, THIS WILL WORK in the Formosa I will build next too!!!
MotOpinion - GWS - E-Starter Hacker B20 18L - 1080 Prop 2.8:1 GWS 350c "A" Gearing gearbox
25ft above Sea Level, 29.92inHg, 70°F
Motor: Hacker B20 18L; 3086rpm/V; 0.4A no-load; 0.092 Ohms.
Battery: Thunder Power TP2100; 2 cells; 2100mAh @ 3.7V; 0.022 Ohms/cell.
Speed Control: Castle Creations Phoenix 35; 0.0045 Ohms; High rate.
Drive System: Generic 9x6in Prop w/3:1 Gearbox; 10x8 (Pconst=1.25; Tconst=0.956) geared 2.8:1 (Eff=95%).
Airframe: GWS E-Starter; 265sq.in; 19.7oz; 10.7oz/sq.ft; Cd=0.055; Cl=0.47; Clopt=0.67; Clmax=1.24.
Stats: 80 W/lb in; 57 W/lb out; 15mph stall; 21mph opt @ 47% (73:50, 75°F); 25mph level @ 54% (55:25, 76°F); 1023ft/min @ 34.1°; -191ft/min @ -6°.
Power System Notes:
The full-throttle motor current at the best lift-to-drag ratio airspeed (14.8A) falls between the motor's maximum efficiency current (5.1A) and its current at theoretical maximum output (32.2A), thus making effective use of the motor.
Possible Aerodynamic Problems:
The diameter (10in) to pitch (8in) ratio is less than 1.5:1, which will result in reduced propeller efficiency at low speeds (the propeller is stalled). Although this is not likely to affect flying characteristics, it may make take-off or hand launching difficult.
Aerodynamic Notes:
The static pitch speed (43mph) is within the range of approximately 2.5 to 3 times the model's stall speed (15mph), which is considered ideal for good performance.
With a wing loading of 10.7oz/sq.ft, a model of this size will have trainer-like flying characteristics. It would make an ideal trainer, for use in calm to light wind conditions.
The static thrust (16.6oz) to weight (19.7oz) ratio is 0.84:1, which will result in very short take-off runs, no difficulty taking off from grass surfaces (assuming sufficiently large wheels), and steep climb-outs.
At the best lift-to-drag ratio airspeed, the excess-thrust (11oz) to weight (19.7oz) ratio is 0.56:1, which will give steep climbs and excellent acceleration. This model should be able to do consecutive loops, and has sufficient in-flight thrust for almost any aerobatic maneuver.
General Notes:
This analysis is based on calculations that take motor heating effects into account.
In-flight Analysis - GWS - E-Starter Hacker B20 18L - 1080 Prop 2.8:1 GWS 350c "A" Gearing gearbox
AirSpd Drag Lift Batt Motor Motor Input Loss MGbOut MotGb Shaft Motor Prop Thrust PSpd Prop Total Time
(mph) (oz) (oz) Amps Amps Volts (W) (W) (W) Ef(%) Ef(%) RPM RPM (oz) (mph) Ef(%) Ef(%) (m:s)
0.0 0.0 0.0 14.6 14.6 6.7 98.0 27.9 70.0 71.5 64.6 15971 5704 16.6 43.2 0.0 0.0 8:36
1.0 0.0 0.0 14.6 14.6 6.7 98.0 27.9 70.0 71.5 64.6 15971 5704 16.4 42.2 2.9 1.9 8:36
2.0 0.0 0.1 14.6 14.6 6.7 98.0 27.9 70.1 71.5 64.6 15969 5703 16.2 41.2 5.7 3.7 8:36
3.0 0.0 0.3 14.7 14.7 6.7 98.1 28.0 70.1 71.5 64.6 15962 5701 16.0 40.2 8.5 5.5 8:36
4.0 0.1 0.5 14.7 14.7 6.7 98.2 28.0 70.1 71.4 64.6 15953 5698 15.8 39.2 11.2 7.2 8:35
5.0 0.1 0.8 14.7 14.7 6.7 98.3 28.1 70.2 71.4 64.5 15943 5694 15.7 38.1 13.8 8.9 8:34
6.0 0.1 1.1 14.7 14.7 6.7 98.4 28.2 70.2 71.4 64.5 15931 5689 15.5 37.1 16.4 10.6 8:34
7.0 0.2 1.6 14.7 14.7 6.7 98.6 28.3 70.3 71.3 64.4 15918 5685 15.3 36.1 18.9 12.2 8:33
8.0 0.2 2.0 14.8 14.8 6.7 98.7 28.4 70.4 71.3 64.4 15904 5680 15.1 35.0 21.4 13.7 8:32
9.0 0.3 2.6 14.8 14.8 6.7 98.9 28.5 70.4 71.2 64.3 15890 5675 15.0 34.0 23.7 15.3 8:31
10.0 0.4 3.2 14.8 14.8 6.7 99.0 28.5 70.5 71.2 64.3 15877 5670 14.8 33.0 26.0 16.7 8:30
11.0 0.5 3.9 14.8 14.8 6.7 99.2 28.6 70.5 71.1 64.2 15863 5665 14.6 31.9 28.3 18.2 8:29
12.0 0.5 4.6 14.9 14.9 6.7 99.3 28.7 70.6 71.1 64.2 15851 5661 14.5 30.9 30.5 19.6 8:28
13.0 0.6 5.4 14.9 14.9 6.7 99.4 28.8 70.6 71.1 64.1 15840 5657 14.3 29.9 32.6 20.9 8:28
14.0 0.7 6.3 14.9 14.9 6.7 99.5 28.8 70.7 71.0 64.1 15831 5654 14.1 28.8 34.6 22.2 8:27
15.0 0.9 7.2 14.9 14.9 6.7 99.6 28.9 70.7 71.0 64.1 15824 5651 13.9 27.8 36.6 23.4 8:27
16.0 1.0 8.2 14.9 14.9 6.7 99.7 28.9 70.7 71.0 64.0 15819 5650 13.7 26.8 38.5 24.6 8:26
17.0 1.1 9.2 14.9 14.9 6.7 99.7 28.9 70.8 71.0 64.0 15817 5649 13.5 25.8 40.3 25.8 8:26
18.0 1.2 10.3 14.9 14.9 6.7 99.6 28.9 70.7 71.0 64.0 15820 5650 13.3 24.8 42.1 26.9 8:27
19.0 1.4 11.5 14.9 14.9 6.7 99.5 28.8 70.7 71.0 64.1 15829 5653 13.1 23.8 43.7 28.0 8:27
20.0 1.5 12.8 14.9 14.9 6.7 99.4 28.7 70.6 71.1 64.1 15845 5659 12.9 22.9 45.3 29.1 8:28
21.0 1.7 14.1 14.8 14.8 6.7 99.1 28.6 70.5 71.1 64.2 15868 5667 12.7 21.9 46.8 30.1 8:30
22.0 1.8 15.5 14.8 14.8 6.7 98.8 28.4 70.4 71.2 64.3 15897 5678 12.4 21.0 48.2 31.0 8:32
23.0 2.0 16.9 14.7 14.7 6.7 98.4 28.2 70.2 71.4 64.5 15933 5690 12.2 20.1 49.5 31.9 8:34
24.0 2.2 18.4 14.6 14.6 6.7 98.0 27.9 70.0 71.5 64.6 15970 5704 12.0 19.2 50.8 32.8 8:36
25.0 2.4 20.0 14.6 14.6 6.7 97.5 27.7 69.8 71.6 64.8 16015 5720 11.7 18.3 52.0 33.7 8:39
26.0 2.6 21.6 14.5 14.5 6.7 96.9 27.3 69.5 71.8 65.0 16068 5739 11.4 17.5 53.1 34.5 8:43
27.0 2.8 23.3 14.3 14.3 6.7 96.2 26.9 69.2 72.0 65.2 16128 5760 11.2 16.6 54.1 35.3 8:47
28.0 3.0 25.0 14.2 14.2 6.7 95.5 26.5 68.9 72.2 65.5 16192 5783 10.9 15.8 55.1 36.0 8:51
29.0 3.2 26.9 14.1 14.1 6.7 94.7 26.1 68.6 72.4 65.7 16262 5808 10.7 15.0 56.0 36.8 8:56
30.0 3.4 28.7 14.0 14.0 6.7 93.8 25.7 68.2 72.7 66.0 16336 5834 10.4 14.2 56.8 37.5 9:02
31.0 3.6 30.7 13.8 13.8 6.7 92.9 25.2 67.7 72.9 66.3 16416 5863 10.1 13.4 57.5 38.2 9:08
32.0 3.9 32.7 13.6 13.6 6.7 91.9 24.7 67.2 73.2 66.6 16501 5893 9.9 12.6 58.2 38.8 9:14
33.0 4.1 34.8 13.5 13.5 6.7 90.9 24.1 66.7 73.4 67.0 16591 5925 9.6 11.9 58.9 39.4 9:21
34.0 4.4 36.9 13.3 13.3 6.8 89.7 23.5 66.2 73.7 67.3 16688 5960 9.3 11.2 59.4 40.0 9:29
35.0 4.6 39.1 13.1 13.1 6.8 88.5 22.9 65.5 74.1 67.7 16793 5998 9.1 10.4 60.0 40.6 9:38
36.0 4.9 41.4 12.9 12.9 6.8 87.1 22.3 64.8 74.4 68.1 16906 6038 8.8 9.7 60.4 41.2 9:48
37.0 5.2 43.7 12.6 12.6 6.8 85.6 21.6 64.0 74.8 68.6 17026 6081 8.5 9.1 60.9 41.7 9:59
38.0 5.5 46.1 12.4 12.4 6.8 84.1 20.9 63.2 75.1 69.0 17153 6126 8.2 8.4 61.2 42.3 10:11
39.0 5.8 48.6 12.1 12.1 6.8 82.5 20.2 62.3 75.5 69.5 17286 6174 7.9 7.8 61.6 42.8 10:25
40.0 6.1 51.1 11.8 11.8 6.8 80.7 19.4 61.3 75.9 70.0 17425 6223 7.6 7.1 61.9 43.3 10:39
41.0 6.4 53.7 11.5 11.5 6.8 78.9 18.7 60.2 76.3 70.6 17570 6275 7.4 6.5 62.1 43.8 10:56
42.0 6.7 56.3 11.2 11.2 6.9 77.0 17.9 59.1 76.7 71.1 17720 6329 7.1 5.9 62.3 44.3 11:13
Note: Motor performance calculations take ambient temperature and heating effects into account.
Generated by MotoCalc 7.08, 3/4/2004 8:18 PM.
