ORIGINAL: MinnFlyer
I've never had a problem running my antenna parallel to the steel pushrods either.
I've noticed on sailboats that handheld VHF reception (especially from distant weather stations) is much better when standing near the mast and shrouds (aluminum mast/stainless cables).
I suppose if you routed an antenna internally for scale or asthetics and it was EXACTLY parallel to a control rod, that rod could shield the antenna if it was directly between you and the antenna. Our transmitters are line-of-sight and relatively weak. So, put the antenna low in the fuselage where the control rods are above it for most flying if you are concerned. One of my first R/C airplanes (a Sig Kadet) had almininum colored Micafilm. It sure flew badly - must have been due to poor reception.
