RE: Pushrods for CG Ultimate .60
I used a Dave Brown Fiberglass push rod with the"Double" end in it. I also drilled the holes out a little and used 4-40 rods instead of the 2-56. You could also use a couple of HS 225s in the rear since you are going with a 120 on it. You will need the tail weight.
Cool color scheme FLYINMIKE
