RCU Forums - View Single Post - DA50 first gasser questions
Old 03-07-2004, 08:28 AM
deputydog
Default RE: DA50 first gasser questions
you can braze(solder) fuel barbs on the end of the brass tubing on the fuel tank. I think Dubro makes them! Or get the smaller Tygon. Also always use some sort of clamp. Either Tie-tie's or the small pinch type sold for our application.
You can also mix up some epoxy with some denatured alcohol and paint it on the foam to seal it.
