RCU Forums - View Single Post - Reversing an S130
Old 03-08-2004, 01:55 PM
ALbert.S
Default RE: Reversing an S130
See if you can unsolder the motor and rotate the motor so the connection are reversed.Then change the pot wires (the two outside ones) and it should work.I did this recently with a 148 it had two screws holding the motor in so just remove them rotate the motor and put the screws back in.Pot and motor MUST be changed or it won't work !!!!!
