RE: Radio Controller Advice
The FCC limits the output to 100 mw which should still give you a 1/4 mile radius range. FM and PCM radios just give you a cleaner signal. If my boat is more than 1/4 mile away, I'm in trouble anyway because at that distance it's a mere spot on the water.
