RCU Forums - View Single Post - Battery for 8 servo setup?
Old 03-12-2004, 11:15 AM
hilleyja
Default RE: Battery for 8 servo setup?
That should be OK. Just keep an eye on your voltage after each flight. I will be running a 6-volt NIMH 1800mah pack on a 28.7%-scale GP Christen Eagle II. It will have (4) airlon servos (Hitec HS-5475s), (2) elevator servos (Hitec HS-5475s), (1) rudder servo (Hitec HS-5975) and (1) throttle servo (Futaba 9304). I'm still working on it and might yet decide to run a redundancy setup, i.e., (2) 6-volt 1800mah NIMH batteries on (2) MPI heavy-duty double-pole switches, connected to 2 channels on my RX.
I have an over-kill setup for my 80" Aeroworks X300L Profile. It has (2) airlon servos (Hitec HS-5625s), (2) elevator servos (Hitec HS-5625s, (1) rudder servo (Hitec HS-5645) and (1) throttle servo (Hitec HS-425). I'm running a 6-volt 3500mah pack on this configuration and can fly all day long. The big pack actually serves a secondary function -- balast for CG.
