RCU Forums - View Single Post - Expo
Thread: Expo
Old 03-14-2004, 04:05 PM
zetor
Default RE: Expo
I have a throttle that I adjusted the servo movement for on my jr 8103. I have almost full throttle at only half the stick movement. There is no bind because I did set the max and minimum throttle movement using the travel adjust function. Is there a way to program this radio to allow for a more uniform transition on the throttle. Each ratchet on the throttle stick should increase rpms a little and I'm not getting that now. The engine is in a half cowl and very hard to get to.
