RE: Go sonic?
there is a guy loverboy g putting NOS into his boats apparently, he is hooked on hitting over 200mph. As for power, if you designed a system that used a turbine to spool up and a cluth that could handle the rpm's then you could redline and drop the clutch. Other than that, maybe rocket power.
