RCU Forums - View Single Post - Which Engine?
Old 03-21-2004 | 08:55 PM
ericheller's Avatar
ericheller
Default RE: Which Engine?
ORIGINAL: Ultima ST
Hmm I kind of need to change my original question...What high performance engines are good that have the short shaft (in other words anything that will fit in the rc10gt)?
Thanks everybody,
Matt
if your looking to race then you should get a .12 and the 7 port is illegal i think. the comment made by XXXNTFREAK is kinda in acurate(at least what i got out of it). slide carbs have good low and high end responce but lack mid range responce. rotary carbs have better midrange and are used alot in off road. slide carbs are used more in on road. have you looked at the fantom .12? im not sure weather if the crank shaft is right but its a great engine.
