RCU Forums - View Single Post - Do I need a Bosch Cap?
Old 03-21-2004 | 11:49 PM
Bass1's Avatar
Bass1
Default Do I need a Bosch Cap?
Hi people, I have a used Brison 3.2 (Blue case) that I just purchased. I have a couple of questions. The spark plug cap is rubber with the ground wire secured to the base of the plug with an automotive type clamp.The ignition wire wire is wrapped with electrical tape from the module to the cap. Is this the standard or do I need the Bosch type cap that I'm seeing lately? If so, where do I get one and Can I install it myself? Also, Coming out of the ignition module is a short 3 wire lead going to a male 3 pin plug that plugs into a two way 3 pin female adaptor which in turn connects to a 3 pin male plug going to the sensor. This seems like alot of connectors to possibly vibrate loose. How do I secure these connectors? Any help would be appreciated. Thanks Ben[sm=confused.gif]
