RE: SIG Rascal Forty in the house!
I am thinking about getting a Rascal 40 ARF. I will also be using a Thunder Tiger Pro 46. How is the engine mounted? I assume the head is to the right with the exhaust pointing down? Did you use an exhaust extension? Are the wing servos mounted inside the wings, with covers, or are they mounted on the surface? I can't find any clear pictures to tell. Thanks.
