RCU Forums - View Single Post - CG Matrix Flight Report...
Old 03-23-2004 | 12:30 PM
tommy s
My Feedback: (55)
Default RE: CG Matrix Flight Report...
I used 20% on ailerons only. I don't think I will need much on elevator as it responds very
positively but is not super sensitive. Rudder has super authority and as I said will do stall
turns on low rate. You can use more aileron travel than they recommend even though they
are very large , probably around 1/2" on low rate. You shouldn't have any problems as it is
a very smooth airplane. I only got in two flights last weekend but I liked it very much.
Good luck
tommy s
PS: use low rate rudder on initial takeoff as rudder is very efective and can make for
squirrely zig-zag takeoff if you're not careful.
