RE: What is 3D Flying?
What?
3D is basically flying the aircraft in a stalled condition, using lots of power and big control movements to make up for lift that would normally be generated by the wing. This allows you to do high angle of attack low passes with the nose at 45 degrees, end over end tumbles and manuvers where the plane drops towards the ground like a parachute, and many other such things.
