RE: less power from 400 motor, 30 esc, 10 cell combo
Basically what you are observing is the result of internal resistance. The smaller 1100mAh cells have a much higher internal resistance than the larger 1700mAh cells. Therefore, the voltage under load will drop more with the small cells. If you specify which types of cells they are, we could get more specific.
-David
