Old 03-25-2004, 11:40 AM
DGrant
DGrant's Avatar
Default RE: Extra 300s .60 Set up
Alot of times I've found I have to use a dremel to shave out the servo holes to accomodate a standard servo. You didn't say what kit you have, only that it's a .60 size Extra. I would question if the torque will be enough with the mini's. I'd have at least 40oz-45oz's of torque for each surface. See what the mini's are rated, while your at it, see if there's a recomemdation in the manual that came with the plane on what's supposed to be in there as far as servo torque. Good luck.
