RE: question
felix . go with the (you can do 46) they are easy to fly & lot of fun & a good plane to get experance no . i agree with daveopam keep the throws down low tto start. ( low throw are when the control serface has smaller amount of movement ) try this set up . place the prush -rod in the servo hole clostiest to center & the other end at the control horn at the hole further away at the out-side . sometime you may have to get longer control horns. GOOD LUCK BILL - WRC-FLYER
