Old 03-25-2004, 10:10 PM
Tired Old Man
Default RE: FuntanS 40 ARF stripping 3004 servos issue
If you want to fly a plane with HUGE control surfaces at maximum throw, and go the extra mile to not fly the plane at high speeds to prevent flutter, the Hitec 225mg is a much better servo for the plane. Unfortunately, it is smaller than the 3004 and will require some modification to the servo opening to mount up.
Otherwise, use a relatively high performance servo for a Funtana. The plane deserves it, and so do you. Both will fly better with equipment above minimum standards.
Go with a metal gear servo.
