Li-po's for receiver and servos only.
Can you use Li-po's to power the receiver and servos in a glow powered plane? It seems that the max voltage for receivers and servos is 6.0 volts. Single cells not enough voltage and two cells to much. Looking into the weight savings over other batteries. Thanks.
