RE: 36MHZ Crystal useability in RX from USA?
Re: importing JR 9X for US use
You could buy one from the UK or Oz and use it, but:
1. It will come factory Mode 1 set up. Most US flyers fly mode 2
2. You can swap the 35 / 36 Mhz Module for a 72 Mhz module
3. The Tx "wall wart" charger will be useless as household electricty is 240~250 volts (US 110 volts) with a different plug pin configuration
4. The Rx will be useless to you - wrong frequency
5. Horizon won't want to know you if you have a "warranty" issue with the set
6. Customs duty?
7. Radio's in the UK and Oz cost lots more than they do in the US so there is no benefit there!
Cheers
fiery
