RCU Forums - View Single Post - prop
Thread: prop
Old 04-01-2004 | 10:48 AM
Montague
Default RE: prop
I don't have an OS .70FS Surpass, but I do have an old OS .61FS (pre-surpass, it's an oldie). I use a 13x6 on it, and have tried 14x5 and 14x6 props, which worked fine (but at a noticeably lower RPM). I never had a 14x4, and I don't think it had enough pitch for my application, so I never tried it. But based on my experiences with my .61, a 14x4 would not be too much prop for a current generation .70 4-stroke. 4-strokes can turn bigger props than 2-strokes.
Many 4-strokes (espeically my .61, but I've seen it with others) have a max RPM that they will run. My .61 would tach exactly the same on a 12x6 and a 13x6 APC. The level flight speed was the same as well (same unloading in the air). But the 13x6 pulled a lot harder, for much better climb. The engine simply would not go faster on the smaller prop. (fwiw, it was turning at around 10k on those props, 8.5k with the 14x6, if I recall. That engine just will not go faster than about 10.5k).
Maybe the .70 is ported differently and set up for higher RPMs and would benifit from a smaller prop, but I kind of doubt it (the smaller prop bit, I'm sure it's ported a bit differently). Also, many 4-strokes get in to valve float problems much over 10k anyway. I don't know if the OS .70 has that problem or not though.
Anyway, get a range of props and try them, that's the only way to know for sure what works best. Start with what's in the engine manual, listen to what other guys say, and don't be affraid to try things just to see how it goes, even if someone else says it won't work. If you go a little at a time, you won't hurt the engine.
